For both the Route 10 and the Control, what is the process to remove personal information from the device?
If you perform a factory reset via Power-on-Reset, it will wipe the raw flash contents of the device: https://help.alta.inc/hc/en-us/articles/41370872297371-Firmware-Bootstrapping-A-K-A-Power-on-Reset
