I know the control UI doesn’t support multiple RADIUS servers for 802.1x enabled SSIDs at this time… is there any way to use the power-user settings or other method to add multiple RADIUS servers in case the first is down?
I’ve tried power-user in the past with hostapd configuration but it never seems to try the second RADIUS server.
Do you have full system logs you can share (via DM) when it’s not trying the second?
OK can you send the system logs?
Closing the loop on this, with @Alta-Jeff 's help we were able to adjust the re-try interval to something lower so that the secondary radius server is hit before the client gives up.
Full power-user config:
"hostapd": "
# Secondary RADIUS auth server
auth_server_addr=1.2.3.4
auth_server_port=1812
auth_server_shared_secret=supersecret123
# Secondary RADIUS acct server
acct_server_addr=1.2.3.4
acct_server_port=1813
acct_server_shared_secret=supersecret123
#Retry timer adjustment
radius_max_retry_wait=1
Thanks again Jeff!
