Port Forward on secondary WAN
Context: WireGuard server is set up on another server, not the router. Existing clients already configured and worked well with previous router.
I have two WAN connections. WAN2 (SFP+) is my primary connection (selected during BLE Setup) behind CGNAT. WAN1 is my secondary connection and has a static IP.
I’d like to configure a port forward for my WireGuard server (192.168.1.50) to only go through WAN1 since it has the static IP, as well as to have the wireguard’s network (172.16.0.0/24) be routed back to the WireGuard server.
How can I go about configuring this?
Have you tried just adding a rule applied to your public static address?
Yes, it did not work
Sorry, I think this may still depend on some upcoming features for now.
This is my use case as well. The incoming direction seems to forward fine, but not the outgoing one. Could there be a workaround firewall rule for this asymmetric routing scenario?
