Instead of painfully assign speed one by one in devices panel, could we set a profile of speed limit that can be set on networks? All devices connected to that network will respect the profile set by default.
You already can do this on wireless networks and on wired devices by setting limits on a different color and assigning it to whatever switch ports you want to.
Nope. I only has 1 trunk link of VLANs to my main switch. Assigning to a port doesn’t work on me. And it’s a normal setup to have a trunk link carrying multiple VLANs. Also is a fuss to set colors than do this and that… it’s very simple request, I just want all the devices connected to that VLAN network set at a certain speed.
Well you can also add limits to entire VLANs assuming you are using the Route10.
