Not sure if its a feature request it might be just me not understanding or missing?
• Is it possible to decide what SSID/VLAN/Network is available on the Meshed NIC “downlink”?
• Is there any way of seeing Wired devices in the dashboard?
• Is there any way of seeing quality of the meshlink / SNR / Speed / Signal
• Is there any place I can Search for a MACaddress to see what AP / SSID etc its connected or if at all?
• Expected the (2 network devices) (4 Devices) (24 Applications) to be clickable.
@reine_halldin Thanks for the feedback! I have the following feedback for you. Please let me know if I have missed the mark on any of these.
• Is it possible to decide what SSID/VLAN/Network is available on the Meshed NIC “downlink”? - By default, we allow all SSID/VLAN/Network on the downlinks. You can then restrict on the individual downlinks via the SSID-Colors assignment, per AP VLAN assignment, etc. If I am missing the point here, please let us know.
• Is there any way of seeing Wired devices in the dashboard? - Yes! This is coming with our network switches.
• Is there any way of seeing quality of the meshlink / SNR / Speed / Signal - Yes! This is coming soon!
• Is there any place I can Search for a MACaddress to see what AP / SSID etc its connected or if at all? - Yes! Under both the Network and Devices tabs, you should see a magnifying glass you can click and search for a MAC address. In the drop down in the right hand side of the screen on the device tab, you can add in AP and SSID so you can see connection details.
• Expected the (2 network devices) (4 Devices) (24 Applications) to be clickable. - This will be clickable in a future update of our UI.
