How do you disable SIP ALG?
This is a very delayed response, but I finally got around to testing @jack findings above, and it doesn’t seem to be working. I may have missed something, but this is printed from my testing tonight.
root@Route10:~# uci set firewall.@zone[0].auto_helper='0'
root@Route10:~# uci set firewall.@zone[0].helper='amanda ftp RAS Q.931 irc pptp snmp tftp'
root@Route10:~# uci commit
root@Route10:~# iptables -traw -vL |grep helper
 2520  533K zone_lan_helper  all  --  br-lan any     anywhere             anywhere             /* !fw3: lan CT helper assignment */
 7294 1836K zone_lan_helper  all  --  br-lan_10 any     anywhere             anywhere             /* !fw3: lan CT helper assignment */
Chain zone_lan_helper (2 references)
    0     0 CT         udp  --  any    any     anywhere             anywhere             /* !fw3: Amanda backup and archiving proto */ udp dpt:10080 CT helper amanda
    0     0 CT         tcp  --  any    any     anywhere             anywhere             /* !fw3: FTP passive connection tracking */ tcp dpt:ftp CT helper ftp
    0     0 CT         udp  --  any    any     anywhere             anywhere             /* !fw3: RAS proto tracking */ udp dpt:1719 CT helper RAS
    0     0 CT         tcp  --  any    any     anywhere             anywhere             /* !fw3: Q.931 proto tracking */ tcp dpt:1720 CT helper Q.931
    0     0 CT         tcp  --  any    any     anywhere             anywhere             /* !fw3: IRC DCC connection tracking */ tcp dpt:ircd CT helper irc
    0     0 CT         tcp  --  any    any     anywhere             anywhere             /* !fw3: PPTP VPN connection tracking */ tcp dpt:1723 CT helper pptp
   79 32420 CT         tcp  --  any    any     anywhere             anywhere             /* !fw3: SIP VoIP connection tracking */ tcp dpt:sip CT helper sip
  183 98152 CT         udp  --  any    any     anywhere             anywhere             /* !fw3: SIP VoIP connection tracking */ udp dpt:sip CT helper sip
    0     0 CT         udp  --  any    any     anywhere             anywhere             /* !fw3: SNMP monitoring connection tracking */ udp dpt:snmp CT helper snmp
    0     0 CT         udp  --  any    any     anywhere             anywhere             /* !fw3: TFTP connection tracking */ udp dpt:tftp CT helper tftp
I think we should also add:
/etc/init.d/firewall reload
after the commit. I’m not sure when that’s needed. It’s not needed on reboot, but I did just see the same thing you saw - and it was fixed by doing the reload. Perhaps it’s an issue when doing configuration changes? I’ll update what I labeled a “solution”.
I was able to disable SIP before using the information in this thread, but now I can’t make it work. Has something changed in the recent updates, and does something else need to be done? Below is what I have in the post-cfg.sh. I run it and /etc/init.d/firewall reload, but after using iptables -t raw -vL | grep helper, I still see:
# Remove SIP lines from modules.d
sed -i -e '/^nf_conntrack_sip$/d' -e '/^nf_nat_sip$/d' /etc/modules.d/nf-nathelper-extra
# Unload modules if they were already loaded
rmmod nf_nat_sip 2>/dev/null
rmmod nf_conntrack_sip 2>/dev/null
uci commit
Please, any help would be appreciated.
IMO, this should be a togglable feature within the UI.
@Alta-MikeD - Any idea on when this will become a feature on the UI?
I see those. Those are in the zone_vpn_helper chain. They should only come into play when going over a vpn. They probably appeared when Alta Labs added a zone for vpn. I’ll see how to get rid of them though. This is all controllable through openwrt and uci.
This should be pretty easy to implement. Openwrt already supports this. I’d suggest checkboxes for all the ALGs openwrt supports - with SIP defaulted to off. Ideally, include some info as to what they do - so they’re not just magic buttons people can press.
Instead of setting zone[0] should instead set defaults[0] - which applies to all zones.
uci set firewall.@defaults[0].helper='amanda ftp RAS Q.931 irc pptp snmp tftp'
# I instead get rid of all of them with: uci set firewall.@defaults[0].helper=''
uci set firewall.@defaults[0].auto_helper='0'
uci commit
Updated to change all zones including vpn
That was still too late to fix the problem. /cfg isn’t mounted until after kmods are loaded.
What did work though was in post-cfg adding to the defaults for all zones:
uci commit
It takes a list, and those are all the ones but sip that were previously active.
To see what’s enabled:
root@route10:~# iptables -traw -vL |grep helper
 2220  344K zone_lan_helper  all  --  br-lan any     anywhere             anywhere             /* !fw3: lan CT helper assignment */
   16  1040 zone_lan_helper  all  --  br-lan_2 any     anywhere             anywhere             /* !fw3: lan CT helper assignment */
   87 11634 zone_lan_helper  all  --  br-lan_3 any     anywhere             anywhere             /* !fw3: lan CT helper assignment */
  131 31281 zone_lan_helper  all  --  br-lan_4 any     anywhere             anywhere             /* !fw3: lan CT helper assignment */
Chain zone_lan_helper (4 references)
