False db amount on AP power
I have been meaning to post about this for a while - would it be possible to ensure you cannot put in a false amount on the db TX power please - i.e anything above max power (which i think varies on region) shouldn’t be accepted in the console or on the app.
Hi @user19 thanks for the report … we can add some front-end validation for that field, but I just tested and the firmware won’t allow what’s allowed in the regulatory fields :slight_smile:
We’ll get that fixed…
That would be great - to help people could you also change the field to show the values you can use i.e 9dBm - 23dBm etc. please?
CleanShot 2024-01-09 at 10.41.37@2x
I agree @user19 we can try to add some min/max values…
