Hi,
It is possible to open a Hotspot by a VLAN? For example If there are a third-party Access Points I want to create a Hotspot on the router on VLAN 100, and create SSID Clients with VLAN100 and If they try to join, the hotspot will popup.
Thanks
Hi,
Thanks
Unfortunately, Hotspot is only available with our APs. If you are using third party access points, they may offer a hotspot feature and you can define the VID 100 in the router.
Any possibility to add this feature?
All feature requests are considered as long as it gets posted in the given category!
