A minor, but probably simple to solve, feature request:
Adding an Enable/Disable switch for logging to syslog host would make life a little bit easier.
Right now, one has to remove the IP to disable logging to remote syslog server, and then try to remember which IP has got the syslog server running to enable it again.
