Controller settings per login session?
When I log in to the cloud controller on a different computer, it appears some settings are back to default. For example, I prefer to have the WiFi signal shown as Raw rather than Icon. It’s confusing (perhaps even frustrating) to try and remember which settings will be the way I left them and which won’t if I used a different browser or computer.
@mikesg Sorry for the frustrations, and I do agree we could make it more clear that those settings do not necessarily follow a user but they follow the local browser settings. For example, if you have multiple accounts that you log in to from the same device, you would want the settings to follow the system that you are on. We’ll try to make that a little more clear at some point.
