Can I manually set speed on switch port?
I have a scenario where I need to force a switch port to 1000mbps full duplex. Is it possible to do that on the 8 port switches?
@rutman286 Sure can! If you click into the individual switch port and scroll down on the new window that pops up, you should see the “speed” drop down where you can hard set 1000mbps full duplex. You also have the download and upload rate limit option just below that.
Screenshot 2024-02-20 at 8.55.23 AM
Thank you sir!
