Blocking/Filtering Content/Applications
If I block applications on the wired side, will it also block applications on the wireless side since it has to run through the Route 10? Or if I want to completely block snapchat, I need to block it on both wired and wireless?
If you want to block Snapchat on both the wired and wireless sides, you will need to create a wireless filter and a wired filter to apply to each one separately.
Anyway to do this on a per network or per device? ie. Only block Snapchat on the Guest and Internet Only network but not the standard network? I guessing manually with firewall rules is the only way right now?
For WiFi, there are many options: per-password, per-profile, per-voucher, and per-client filters. For wired, it’s all or nothing right now, but we are working on improving that.
