same issues with airprint my printer disconnects totally went to device and saw it was not even connected
google nest speaker just lost connection tottally
Setting to “Large” helped it work longer… I got almost 5 hours that time before things started acting weird again. But alas, eventually the same disconnects.
Have you changed any of the air-time efficiency settings? On my IoT SSID I set the min rate to 6000 Kbps for 2.4Ghz and left 5Ghz on auto.
I have. This is not a problem of the devices losing connection to the APs. This is a problem of multicast traffic being stopped by something running on the APs.
This is so odd, I did like @JRosen suggested, changed to Large Network and Enabled both Fast Roaming and IGMP Proxy option (BBS Transition was on by default).
It has been 9 hours and I’m still able to use airprint and communicate to the other devices that were not working before. However this has introduced other issues like devices constantly changing AP’s and my 2nd AP6-Pro that is in mesh mode keeps disconnecting and reconnecting every few hours.
Hi guys, we’ll get to the bottom of this… I’ll contact some of you directly.
-Matt
Thank you @Alta-MattH! I REALLY want to use these APs.
Can you guys list your devices and models you’re using for airplay/airprint? So we can keep a list, and try to find commonalities?
Apple TV 4K first gen - WiFi connected
Apple TV 4K 3rd gen - WiFi connected
HomePod mini first gen - WiFi connected
HP OfficeJet Pro 9020 - Hardwired
All devices are on the same VLAN as the laptops / iPads that are being used for airplay / AirPrint.
AppleTV 4k 2nd Gen - Wireless
AppleTV 4K 3rd Gen - Hardwired
3 HomePod Mini’s - Wireless
HomePod 1st Gen - Wireless
Sonos Arc - Wireless
HP Envy Pro 6455 - Wireless
@JRosen are you using different VLANs?
Yes, Apple devices are on the default VLAN along with phones, tablets and computers. IoT devices are on separate VLAN.
HP Officejet Pro 6830
Elgato Key Light Air’s
Roku Express
Roku streaming stick 4k
Roku TV (TCL Model: 55P605)
Apple TV 4K
MacOS and iOS clip board sharing not working. I used to be able to copy text on my Macbook Pro, and then just pick up my phone and Past the text from the macbook
I have management vlan set to 1, All these devices are set to another vlan via wifi password. All of the devices are getting IP’s from the correct vlan range.
